Ana içeriğe geç
Garmin Dezl 760LMT Speaker Replacement
Neye ihtiyacın var
  1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: adım 1, 2 resimden 1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Speaker Replacement: adım 2, 3 resimden 1. Garmin Dezl 760LMT Speaker Replacement: adım 2, 3 resimden 2. Garmin Dezl 760LMT Speaker Replacement: adım 2, 3 resimden 3.
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Speaker Replacement: adım 3, 1 resimden 1.
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Speaker Replacement, Speaker: adım 4, 2 resimden 1. Garmin Dezl 760LMT Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
    • Slide the metal probe underneath the speaker and pry upwards.
    • During reassembly, use electrical tape to hold the speaker into place.
  5. Garmin Dezl 760LMT Speaker Replacement: adım 5, 2 resimden 1. Garmin Dezl 760LMT Speaker Replacement: adım 5, 2 resimden 2.
    • Grasp the speaker wire near the motherboard and lift upward to detach the connector.
Sonuç
Ryan Williams
763 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 532
