Ana içeriğe geç
Garmin Dezl 770LMT Battery Replacement
Neye ihtiyacın var
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: adım 1, 2 resimden 1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: adım 1, 2 resimden 2.
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: adım 2, 1 resimden 1.
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: adım 3, 1 resimden 1.
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: adım 4, 3 resimden 1. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: adım 4, 3 resimden 2. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: adım 4, 3 resimden 3.
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: adım 5, 2 resimden 1. Garmin Dezl 770LMT Battery Replacement: adım 5, 2 resimden 2.
    • Grasp the wire near the mother board and gently lift to detach the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Francisco Rosado
370 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 27
Her zaman: 6,057
