Ana içeriğe geç
Garmin Dezl 770LMT Screen Replacement
Neye ihtiyacın var
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: adım 1, 2 resimden 1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: adım 1, 2 resimden 2.
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Screen Replacement: adım 2, 1 resimden 1.
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Screen Replacement: adım 3, 1 resimden 1.
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Screen Replacement, Screen: adım 4, 2 resimden 1. Garmin Dezl 770LMT Screen Replacement, Screen: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Screen Replacement: adım 5, 3 resimden 1. Garmin Dezl 770LMT Screen Replacement: adım 5, 3 resimden 2. Garmin Dezl 770LMT Screen Replacement: adım 5, 3 resimden 3.
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
  6. Garmin Dezl 770LMT Screen Replacement: adım 6, 1 resimden 1.
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Aleem Waris
146 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 3,024
