Ana içeriğe geç
Garmin Dezl 770LMT Speaker Replacement
Neye ihtiyacın var
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: adım 1, 2 resimden 1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: adım 1, 2 resimden 2.
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: adım 2, 1 resimden 1.
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: adım 3, 1 resimden 1.
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: adım 4, 2 resimden 1. Garmin Dezl 770LMT Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: adım 5, 2 resimden 1. Garmin Dezl 770LMT Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Sonuç
Francisco Rosado
370 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 üyesi
USFT-LACY-F16S1G3
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
do u know where i can get a replacement speaker
markrushforth65 - Yanıt
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,057
