Ana içeriğe geç
Garmin Drive 52 and Traffic Battery Replacement
Neye ihtiyacın var
  1. Garmin Drive 52 and Traffic Battery Replacement, Battery: adım 1, 3 resimden 1. Garmin Drive 52 and Traffic Battery Replacement, Battery: adım 1, 3 resimden 2. Garmin Drive 52 and Traffic Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
    • If necessary, use a Jimmy or other pry tool to open the backside of the device.
  2. Garmin Drive 52 and Traffic Battery Replacement: adım 2, 3 resimden 1. Garmin Drive 52 and Traffic Battery Replacement: adım 2, 3 resimden 2. Garmin Drive 52 and Traffic Battery Replacement: adım 2, 3 resimden 3.
    • Once the back side is open, flip the ZIF connector's lock bar up then remove the connector.
  3. Garmin Drive 52 and Traffic Battery Replacement: adım 3, 3 resimden 1. Garmin Drive 52 and Traffic Battery Replacement: adım 3, 3 resimden 2. Garmin Drive 52 and Traffic Battery Replacement: adım 3, 3 resimden 3.
    • Use a T5 Torx screwdriver to unscrew the four screws securing the motherboard.
    • Gently detach the wiring from the motherboard and left the motherboard out.
    • Use a nylon spudger to gently lift the battery out.
    • Avoid using metal spudgers near batteries; puncturing or excessively warping batteries can be dangerous.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jason Wilson
388 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Petersen Fall 2022 UMass Dartmouth, Team 1-2, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S1G2
6 Üyeler
1Rehber Yorum
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
Chris Massey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 78
Her zaman: 1,361
