Giriş
Over time, the battery in your Garmin Drive 52 and Traffic device may lose its ability to retain charge, making it less reliable during use. This guide walks you through replacing the battery on your device to restore its performance and extend its overall life. No specialized skills like soldering or programming are required. Whether you're experiencing rapid battery drain or complete power loss, this repair is an easy solution.
Before you begin, turn off your device and unplug it from the charger.
Neye ihtiyacın var
Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
If necessary, use a Jimmy or other pry tool to open the backside of the device.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
