Giriş
This guide helps you to replace the motherboard of the Garmin Drive 52 & Traffic GPS.
The motherboard is the central hub of your GPS device, responsible for connecting and powering all its internal components. Over time, damage or wear can cause symptoms like unresponsiveness, persistent error messages, or total device failure.
Always disconnect the device from any power source and ensure it is powered down before you begin.
Neye ihtiyacın var
Pop the suction cup off of the device.
Unscrew the four T5 Torx screws on the back.
Carefully pry apart the front and back with a Jimmy.
