Ana içeriğe geç
Garmin Drive 60LM Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Garmin Drive 60LM Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: adım 2, 3 resimden 1. Garmin Drive 60LM Motherboard Replacement: adım 2, 3 resimden 2. Garmin Drive 60LM Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Motherboard Replacement: adım 3, 3 resimden 1. Garmin Drive 60LM Motherboard Replacement: adım 3, 3 resimden 2. Garmin Drive 60LM Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: adım 4, 2 resimden 1. Garmin Drive 60LM Motherboard Replacement: adım 4, 2 resimden 2.
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: adım 5, 2 resimden 1. Garmin Drive 60LM Motherboard Replacement: adım 5, 2 resimden 2.
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andy Flores
247 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S3G3
4 Üyeler
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - Yanıt
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,487
