Ana içeriğe geç
Garmin Drive 60LM Speaker Replacement
Neye ihtiyacın var
  1. Garmin Drive 60LM Speaker Replacement, Speaker: adım 1, 2 resimden 1. Garmin Drive 60LM Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Speaker Replacement: adım 2, 3 resimden 1. Garmin Drive 60LM Speaker Replacement: adım 2, 3 resimden 2. Garmin Drive 60LM Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the back panel using the metal spudger tool.
    • You will not be able to remove the back panel entirely. Make sure to separate the back panel slowly so that you do not rip the orange ribbon inside.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Speaker Replacement: adım 3, 3 resimden 1. Garmin Drive 60LM Speaker Replacement: adım 3, 3 resimden 2. Garmin Drive 60LM Speaker Replacement: adım 3, 3 resimden 3.
    • Use a plastic spudger tool to lift the wires from behind the motherboard.
    • Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
  4. Garmin Drive 60LM Speaker Replacement: adım 4, 2 resimden 1. Garmin Drive 60LM Speaker Replacement: adım 4, 2 resimden 2.
    • Using a plastic spudger and your fingers, remove the speaker from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andy Flores
247 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S3G3
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 546
