Ana içeriğe geç
Garmin Edge 1000 Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Edge 1000 Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Garmin Edge 1000 Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Motherboard Replacement: adım 2, 2 resimden 1. Garmin Edge 1000 Motherboard Replacement: adım 2, 2 resimden 2.
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Garmin Edge 1000 Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Garmin Edge 1000 Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Remove the three T6 Torx screws to release the motherboard.
  4. Garmin Edge 1000 Motherboard Replacement: adım 4, 2 resimden 1. Garmin Edge 1000 Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the two bronze tabs connected to the motherboard using an opening tool.
  5. Garmin Edge 1000 Motherboard Replacement: adım 5, 2 resimden 1. Garmin Edge 1000 Motherboard Replacement: adım 5, 2 resimden 2.
    • Pull the motherboard out from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Bonjour
Je cherche la référence du connecteur qui relie l’écran LCD à la carte mère
Il s’agit du connecteur FCP de 50 pins.
Pouvez vous me dire ou je pourrais trouver cette pièce?
En vous remerciant par avance
Stephane Weymeels - Yanıt
How about software?
Leslie Poh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,378
