Ana içeriğe geç
Garmin Edge 830 Back Cover Replacement
Neye ihtiyacın var
  1. Garmin Edge 830 Back Cover Replacement, Touch Display: adım 1, 1 resimden 1.
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 Back Cover Replacement: adım 2, 1 resimden 1.
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 Back Cover Replacement: adım 3, 1 resimden 1.
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Back Cover Replacement, Motherboard: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Back Cover Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Back Cover Replacement: adım 6, 1 resimden 1.
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Back Cover Replacement: adım 7, 2 resimden 1. Garmin Edge 830 Back Cover Replacement: adım 7, 2 resimden 2.
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 Back Cover Replacement, Battery: adım 8, 1 resimden 1.
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 Back Cover Replacement, Back Cover: adım 9, 1 resimden 1.
    • Once all previous steps are completed, you will be left with the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alden Gibbs
265 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
What are the steps required to put the screen back on? What glue should we use and how?
Odhita Kamayana - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 92
Her zaman: 1,531
