Giriş
If you find yourself on this guide, it means that you are having problems attaching your Garmin Edge 830 to its respective mount. The best solution to this is to replace the back cover . In order to do this you will have to take the device apart in its entirety. This may sound like a lot of work, but we have attached all the required steps that will have you done in a timely manner. Make sure you keep track of all your parts/screws along the way.
Neye ihtiyacın var
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Alternative: Use a heat gun or hair dryer to heat up the glue
Use the Jimmy tool carve around the edges of the screen to break the glue seal.
Bu adımda kullanılan alet:Tweezers$3.99
Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
Once all previous steps are completed, you will be left with the back cover.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
What are the steps required to put the screen back on? What glue should we use and how?
I have a 820 is the same process used?
Gary Roy Hogg - Yanıt
