Ana içeriğe geç
Garmin Fenix 2 Battery Replacement
Neye ihtiyacın var
  1. Garmin Fenix 2 Battery Replacement, Battery: adım 1, 3 resimden 1. Garmin Fenix 2 Battery Replacement, Battery: adım 1, 3 resimden 2. Garmin Fenix 2 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Battery Replacement: adım 2, 2 resimden 1. Garmin Fenix 2 Battery Replacement: adım 2, 2 resimden 2.
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Battery Replacement: adım 3, 2 resimden 1. Garmin Fenix 2 Battery Replacement: adım 3, 2 resimden 2.
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Brandon Barger
1.219 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S54G4
3 Üyeler
7 adet Kılavuz yazıldı
7Kılavuz Yorumları
can you tell us exactly which battery should be used? Thanks in advance!
fabrizionannini - Yanıt
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
homanchris -
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
https://buy.garmin.com/en-US/US/into-spo...
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
L P - Yanıt
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
Yang - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 54
Son 30 gün: 194
Her zaman: 35,025
