Giriş
We will remove all of the components from the watch in order to replace the housing. You will need a nylon spudger and Torx T9 screwdriver.
Neye ihtiyacın var
Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
do you know where i can find atmospheric pressure and temperature sensors?
