Ana içeriğe geç
Garmin Fenix 3 GPS Antenna Replacement
Neye ihtiyacın var
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: adım 1, 2 resimden 1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: adım 2, 1 resimden 1.
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: adım 3, 1 resimden 1.
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: adım 4, 1 resimden 1.
    • Set the watch face aside.
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: adım 5, 1 resimden 1.
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: adım 6, 1 resimden 1.
    • Carefully remove the antenna, and set it aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
8Kılavuz Yorumları
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - Yanıt
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - Yanıt
Hi did you find gps antenna
Abdessamad Faroque - Yanıt
Could you please add a link where to buy the antenna?
marco475 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 81
Her zaman: 6,593
