Ana içeriğe geç
Garmin Fenix 3 HR "self made charging"
Neye ihtiyacın var
  1. Garmin Fenix 3 HR "self made charging", Garmin Fenix 3 HR "self made charging": adım 1, 2 resimden 1. Garmin Fenix 3 HR "self made charging", Garmin Fenix 3 HR "self made charging": adım 1, 2 resimden 2.
    • Insert wisdom here.
  2. Garmin Fenix 3 HR "self made charging": adım 2, 1 resimden 1.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
9Kılavuz Yorumları
great job, very easy to do it. The hard part is that the wiring is too small :)
thank you
Pedro R. - Yanıt
Thank you, David704. Your guide save me 13.50$ and a 3 day wait.
asads zia - Yanıt
Thank you.. forgot charger at work before vacation.. thank youuuu :)
jakadels - Yanıt
Thank you! You just saved my step streak :)
Magnus Berg - Yanıt
quiero que me cheque un garmin istinct que no recibe carga
Victor Manuel Perez Rodriguez - Yanıt
Forgot my charger during a trip and found this guide. Works like a charm! Thank you for this nifty guide! Works well for Garmin Fenix 3 HR.
helenaandprashant - Yanıt
Worked great thanks. The only hard part was that the wires are small.
Manuel Reverie - Yanıt
Since the original charging connector plug is symmetrical and can be connected either way around, it's very likely that you can connect the + and - either way around. Just be sure to connect to pin 1 and pin 4 and you should be good.
David P. Ingram - Yanıt
Not sure about the polarity, for me it only worked for red (positive) clamped to the pin next to the CE/BT signs (bottom).
Assuming that I had no contact issues for my first couple of attempts with the inverted polarity and that the cable had standard colour coding.
Anna Mayo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 12,788
