Ana içeriğe geç
Garmin Fenix 3 HR Battery Replacement
Neye ihtiyacın var
  1. Garmin Fenix 3 HR Battery Replacement, Battery: adım 1, 2 resimden 1. Garmin Fenix 3 HR Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: adım 2, 3 resimden 1. Garmin Fenix 3 HR Battery Replacement: adım 2, 3 resimden 2. Garmin Fenix 3 HR Battery Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: adım 4, 2 resimden 1. Garmin Fenix 3 HR Battery Replacement: adım 4, 2 resimden 2.
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: adım 5, 1 resimden 1.
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: adım 6, 1 resimden 1.
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: adım 7, 1 resimden 1.
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: adım 8, 1 resimden 1.
    • Now attach the new battery with adhesive and reassemble.
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Victor Tanguy
1.329 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G6
3 Üyeler
5 adet Kılavuz yazıldı
29 Yorum
Does anybody do It in a fenix 5?
Fernando Alcaraz - Yanıt
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Yanıt
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 66
Son 30 gün: 350
Her zaman: 70,839
