Ana içeriğe geç
Garmin Fenix 3 HR Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: adım 2, 2 resimden 1. Garmin Fenix 3 HR Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: adım 4, 2 resimden 1. Garmin Fenix 3 HR Motherboard Replacement: adım 4, 2 resimden 2.
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: adım 5, 1 resimden 1.
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: adım 6, 1 resimden 1.
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: adım 7, 1 resimden 1.
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: adım 8, 1 resimden 1.
    • Now attach battery to new motherboard and reassemble.
    Where can i get a new motherboard
    merlion chan - Yanıt
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jacob Smiley
277 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G6
3 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
And where would one source replacement motherboard?
jonathan.hatchuel - Yanıt
donde puedo encontras placa.madre reeemplazo????
luis zavala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 5,018
