Ana içeriğe geç
Garmin Fenix 3 Wrist Strap Replacement
Neye ihtiyacın var
  1. Garmin Fenix 3 Wrist Strap Replacement, Wrist Strap: adım 1, 1 resimden 1.
    • Identify the screws near the bases of two wrist straps.
  2. Garmin Fenix 3 Wrist Strap Replacement: adım 2, 1 resimden 1.
    • Hold one screwdriver firmly in one hand, as demonstrated in the image.
  3. Garmin Fenix 3 Wrist Strap Replacement: adım 3, 1 resimden 1.
    • Secure the watch in the same hand, positioning the screwdriver over the screw.
  4. Garmin Fenix 3 Wrist Strap Replacement: adım 4, 1 resimden 1.
    • Once the watch is secure, insert the screwdriver into the screw, and hold firmly.
  5. Garmin Fenix 3 Wrist Strap Replacement: adım 5, 1 resimden 1.
    • With the watch and the first screwdriver secure, insert the second screwdriver into the opposite screw.
    • Holding the first screwdriver firmly, unscrew using the second screwdriver.
  6. Garmin Fenix 3 Wrist Strap Replacement: adım 6, 1 resimden 1.
    • Remove the bar from the wrist strap to release.
    • Depending on which side the bar is inserted, you may end up loosening the screw instead of the bar. Keep this in mind to avoid losing your screws.
  7. Garmin Fenix 3 Wrist Strap Replacement: adım 7, 1 resimden 1.
    • Repeat this process for the other side, adjusting the position of the watch accordingly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 3,685
