Ana içeriğe geç
Garmin Forerunner 25 Battery Replacement
Neye ihtiyacın var
  1. Garmin Forerunner 25 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: adım 2, 1 resimden 1.
    • Pry the old battery out using a plastic spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Persohn
235 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G3
3 Üyeler
5 adet Kılavuz yazıldı
11Kılavuz Yorumları
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Yanıt
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Yanıt
Just look at the last picture. PD2430C1
Leandro Lind - Yanıt
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Yanıt
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 24
Son 30 gün: 105
Her zaman: 7,224
