Ana içeriğe geç
Garmin Forerunner 25 Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: adım 5, 1 resimden 1.
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Persohn
235 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 896
