Ana içeriğe geç
Garmin Forerunner 25 Watchband Replacement
  1. Garmin Forerunner 25 Watchband Replacement, Starting pieces: adım 1, 2 resimden 1. Garmin Forerunner 25 Watchband Replacement, Starting pieces: adım 1, 2 resimden 2.
    • Assemble the watch with the broken wristband, along with the replacement parts. I don't have many specific suggestions here. I just googled watchband replacement for the Garmin Forerunner 25 and found this package for $6.99 on Amazon. It came with the small screwdrivers you will need to swap out the wristband, so I considered this a good price.
  2. Garmin Forerunner 25 Watchband Replacement, Remove watchband using screwdriver: adım 2, 2 resimden 1. Garmin Forerunner 25 Watchband Replacement, Remove watchband using screwdriver: adım 2, 2 resimden 2.
    • Pretty simple, but insert one screwdriver on either side and hold one in place while loosening the other side (lefty loosey, rightey tightey). It takes more turning than initially expected, but comes apart eventually into two interlocking screws.
  3. Garmin Forerunner 25 Watchband Replacement, Insert new watch band: adım 3, 2 resimden 1. Garmin Forerunner 25 Watchband Replacement, Insert new watch band: adım 3, 2 resimden 2.
    • Align new watch band, insert the screws, and do the inverse of what you did to tighten the screws through the watchband, rightey tightey.
  4. Garmin Forerunner 25 Watchband Replacement, Repeat on other watchband to finish the job.: adım 4, 2 resimden 1. Garmin Forerunner 25 Watchband Replacement, Repeat on other watchband to finish the job.: adım 4, 2 resimden 2.
    • Repeat the same removal and replacement steps on the other side. This was my first time doing it, and as you can see from the timing on the watch it took me less than 15 minutes total. New silicone band is quite comfortable and sturdy. In all, it took about 5 days for the band to be delivered and $6.99 total, plus 15 mins to replace myself.
Sonuç
Nathan Scinto-Madonich
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 752
