Ana içeriğe geç
Garmin Forerunner 405 Button Replacement
Neye ihtiyacın var
    1. Garmin Forerunner 405 Button Replacement, Unscrew backing: adım 1, 1 resimden 1.
      • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
      FixBot'a Sor
      Yorum Ekle
    2. Garmin Forerunner 405 Button Replacement, Separate Component: adım 2, 1 resimden 1.
      • Pull the backing off the watch.
      FixBot'a Sor
      Yorum Ekle
    3. Garmin Forerunner 405 Button Replacement, Separate: adım 3, 1 resimden 1.
      • Pull the battery wires out from the motherboard slowly.
      FixBot'a Sor
      Yorum Ekle
    4. Garmin Forerunner 405 Button Replacement, Unscrew: adım 4, 1 resimden 1.
      • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
      • Lift the motherboard out of the watch.
      FixBot'a Sor
      Yorum Ekle
    5. Garmin Forerunner 405 Button Replacement, Pull apart: adım 5, 2 resimden 1. Garmin Forerunner 405 Button Replacement, Pull apart: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Push button in and pinch silver clip with tweezers.
      • Pull silver clip off the pin it is on.
      • Pull out button and replace.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kyle Kiwczak
328 İtibar
3 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Yanıt Paylaş
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 4,100
