Ana içeriğe geç
Garmin Forerunner 735XT Strap Replacement
Neye ihtiyacın var
  1. Garmin Forerunner 735XT Strap Replacement, Remove the strap screws.: adım 1, 1 resimden 1.
    • Using two T6 screwdrivers, remove the old strap.
    • Turn the right hand screw anti-clockwise. This is the shorter of the two.
    • Two screwdrivers are needed to hold one screw in place while you turn the other one.
  2. Garmin Forerunner 735XT Strap Replacement, Remove the strap bar: adım 2, 3 resimden 1. Garmin Forerunner 735XT Strap Replacement, Remove the strap bar: adım 2, 3 resimden 2. Garmin Forerunner 735XT Strap Replacement, Remove the strap bar: adım 2, 3 resimden 3.
    • With the small screw removed, you can use one of the screwdrivers to push out the long bar securing the strap.
    • Repeat this step for the other half of the strap.
  3. Garmin Forerunner 735XT Strap Replacement: adım 3, 1 resimden 1.
    • With both of the old straps off, you can now fit the new one.
    • Slide the long bar through the watch and the strap, then attach the small screw back into it.
    • You will need to use both screwdrivers again (one to hold a screw in place, the other to turn.
Sonuç
jackacon
614 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 54
Her zaman: 792
