Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Orient the GPS V backside up.
With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
Orient the front plate of the device so the display board is facing up.
With the spudger, gently work your way around the display assembly.
Pry the display free of the front plate.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
This is very helpful - especially when having problems with display (vertical or horizontal lines missing). With your detailed aid it is possible, to remove the display connector, to softly grind it, making contacts conductive again, cleaning them and reassembly the connector - then display was healed - really great help!!
