Neye ihtiyacın var
Orient the GPS V backside up.
With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
Orient the front plate of the device so the display board is facing up.
With the spudger, gently work your way around the display assembly.
Pry the display free of the front plate.
With the display removed, the front case of the Garmin GPS can be replaced.
Bir başkası bu kılavuzu tamamladı.
