Ana içeriğe geç
Garmin GPS V Logic Board Replacement
Neye ihtiyacın var
  1. Garmin GPS V Logic Board Replacement, Logic Board: adım 1, 3 resimden 1. Garmin GPS V Logic Board Replacement, Logic Board: adım 1, 3 resimden 2. Garmin GPS V Logic Board Replacement, Logic Board: adım 1, 3 resimden 3.
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Logic Board Replacement: adım 2, 2 resimden 1. Garmin GPS V Logic Board Replacement: adım 2, 2 resimden 2.
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Logic Board Replacement: adım 3, 2 resimden 1. Garmin GPS V Logic Board Replacement: adım 3, 2 resimden 2.
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Logic Board Replacement: adım 4, 2 resimden 1. Garmin GPS V Logic Board Replacement: adım 4, 2 resimden 2.
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Logic Board Replacement: adım 5, 3 resimden 1. Garmin GPS V Logic Board Replacement: adım 5, 3 resimden 2. Garmin GPS V Logic Board Replacement: adım 5, 3 resimden 3.
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Logic Board Replacement: adım 6, 2 resimden 1. Garmin GPS V Logic Board Replacement: adım 6, 2 resimden 2.
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Logic Board Replacement: adım 7, 1 resimden 1.
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Connor
194 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-25, Amido Winter 2012 Cal Poly, Team 3-25, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G25
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 5,636
