Ana içeriğe geç
Garmin GPSmap 60CSx Battery Terminal Replacement
Neye ihtiyacın var
  1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: adım 1, 1 resimden 1.
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 2, 1 resimden 1.
    • Lift battery release up to remove battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 3, 2 resimden 1. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 3, 2 resimden 2.
    • Pull AA batteries out.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: adım 4, 1 resimden 1.
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 5, 2 resimden 1. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 5, 2 resimden 2.
    • Place spudger behind the lower right battery terminal.
    • Push spudger behind the battery terminal to pop it out of place.
    • Now do the same on the bottom left side.
    FixBot'a Sor
    Yorum Ekle
  6. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 6, 2 resimden 1. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 6, 2 resimden 2.
    • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
    FixBot'a Sor
    Yorum Ekle
  7. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 7, 2 resimden 1. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 7, 2 resimden 2.
    • Flip the back panel over to expose the backs of the top battery terminals.
    • Use a metal spudger to remove the glue that covers them.
    FixBot'a Sor
    Yorum Ekle
  8. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 8, 2 resimden 1. Garmin GPSmap 60CSx Battery Terminal Replacement: adım 8, 2 resimden 2.
    • Flip the back panel back over to view the battery compartment.
    • Place the spudger behind one of the top remaining battery terminals.
    • Push the spudger down and pop the battery terminal out of place.
    • Repeat with the remaining battery terminal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
10Kılavuz Yorumları
What did you use to replace the contacts?
Austin Chopra - Yanıt Paylaş
Where can I buy replacement terminals?
Mitch - Yanıt Paylaş
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons - Yanıt Paylaş
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - Yanıt Paylaş
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 98
Her zaman: 12,120
