Ana içeriğe geç
Garmin GPSmap 60CSx Keypad Buttons Replacement
Neye ihtiyacın var
  1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: adım 1, 1 resimden 1.
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 2, 1 resimden 1.
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 3, 2 resimden 1. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 3, 2 resimden 2.
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: adım 4, 2 resimden 1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: adım 4, 2 resimden 2.
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 5, 1 resimden 1.
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
  6. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 6, 2 resimden 1. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 6, 2 resimden 2.
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
  7. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 7, 2 resimden 1. Garmin GPSmap 60CSx Keypad Buttons Replacement: adım 7, 2 resimden 2.
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 3,051
