Ana içeriğe geç
Garmin GPSmap 60CSx Screen Replacement
Neye ihtiyacın var
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: adım 1, 1 resimden 1.
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin GPSmap 60CSx Screen Replacement: adım 2, 1 resimden 1.
    • Lift battery release up to remove battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin GPSmap 60CSx Screen Replacement: adım 3, 2 resimden 1. Garmin GPSmap 60CSx Screen Replacement: adım 3, 2 resimden 2.
    • Pull AA batteries out.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: adım 4, 2 resimden 1. Garmin GPSmap 60CSx Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin GPSmap 60CSx Screen Replacement: adım 5, 1 resimden 1.
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
    FixBot'a Sor
    Yorum Ekle
  6. Garmin GPSmap 60CSx Screen Replacement: adım 6, 2 resimden 1. Garmin GPSmap 60CSx Screen Replacement: adım 6, 2 resimden 2.
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
    FixBot'a Sor
    Yorum Ekle
  7. Garmin GPSmap 60CSx Screen Replacement: adım 7, 3 resimden 1. Garmin GPSmap 60CSx Screen Replacement: adım 7, 3 resimden 2. Garmin GPSmap 60CSx Screen Replacement: adım 7, 3 resimden 3.
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
    FixBot'a Sor
    Yorum Ekle
  8. Garmin GPSmap 60CSx Screen Replacement: adım 8, 1 resimden 1.
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
    FixBot'a Sor
    Yorum Ekle
  9. Garmin GPSmap 60CSx Screen Replacement: adım 9, 3 resimden 1. Garmin GPSmap 60CSx Screen Replacement: adım 9, 3 resimden 2. Garmin GPSmap 60CSx Screen Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the two white pins on the connector forward.
    FixBot'a Sor
    Yorum Ekle
  10. Garmin GPSmap 60CSx Screen Replacement: adım 10, 1 resimden 1.
    • Remove the screen ribbon connector and screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Yanıt Paylaş
Thank you for these step by step detailed instructions.
jlciscorp - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 48
Her zaman: 5,716
