Giriş
In this guide the repairer replaces the LCD display of the device by carefully prying apart the components with one's hands.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
- None
Estimated Duration: 5 minutes
Neye ihtiyacın var
Unscrew the two screws on the antenna unit using a torc-head screwdriver.
Gently pry open the antenna unit with your fingers.
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Bir başkası bu kılavuzu tamamladı.
