Ana içeriğe geç
Garmin Nüvi 205W LCD Display Replacement
Neye ihtiyacın var
  1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: adım 1, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: adım 1, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement, LCD Display: adım 1, 3 resimden 3.
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Garmin Nüvi 205W LCD Display Replacement: adım 2, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement: adım 2, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement: adım 2, 3 resimden 3.
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
  3. Garmin Nüvi 205W LCD Display Replacement: adım 3, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement: adım 3, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement: adım 3, 3 resimden 3.
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
  4. Garmin Nüvi 205W LCD Display Replacement: adım 4, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement: adım 4, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement: adım 4, 3 resimden 3.
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
  5. Garmin Nüvi 205W LCD Display Replacement: adım 5, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement: adım 5, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement: adım 5, 3 resimden 3.
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
  6. Garmin Nüvi 205W LCD Display Replacement: adım 6, 3 resimden 1. Garmin Nüvi 205W LCD Display Replacement: adım 6, 3 resimden 2. Garmin Nüvi 205W LCD Display Replacement: adım 6, 3 resimden 3.
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
oldturkey03
814.130 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
2Kılavuz Yorumları
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - Yanıt
Thank you! Saved me a new GPS!
worthless0000 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 3,466
