Ana içeriğe geç
Garmin Nuvi 1390LMT Logic Board Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 1390LMT Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Logic Board Replacement: adım 2, 2 resimden 1. Garmin Nuvi 1390LMT Logic Board Replacement: adım 2, 2 resimden 2.
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Logic Board Replacement: adım 3, 1 resimden 1.
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Logic Board Replacement: adım 4, 1 resimden 1.
    • Gently pull the wire ribbon connecting the screen to the logic board from the plug.
    • Be careful when unplugging the wire ribbon. It is very fragile.
  5. Garmin Nuvi 1390LMT Logic Board Replacement: adım 5, 1 resimden 1.
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Logic Board Replacement: adım 6, 1 resimden 1.
    • Flip the logic board over.
  7. Garmin Nuvi 1390LMT Logic Board Replacement: adım 7, 2 resimden 1. Garmin Nuvi 1390LMT Logic Board Replacement: adım 7, 2 resimden 2.
    • Disconnect the harness between the battery and the logic board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Trey Ulsh
537 İtibar
3 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S10G4
5 Üyeler
1Rehber Yorum
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
Danny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 988
