Ana içeriğe geç
Garmin Nuvi 1490T Speaker Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: adım 1, 1 resimden 1.
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: adım 2, 1 resimden 1.
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: adım 3, 2 resimden 1. Garmin Nuvi 1490T Speaker Replacement: adım 3, 2 resimden 2.
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: adım 4, 3 resimden 1. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: adım 4, 3 resimden 2. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: adım 4, 3 resimden 3.
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: adım 5, 3 resimden 1. Garmin Nuvi 1490T Speaker Replacement: adım 5, 3 resimden 2. Garmin Nuvi 1490T Speaker Replacement: adım 5, 3 resimden 3.
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: adım 6, 2 resimden 1. Garmin Nuvi 1490T Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: adım 7, 2 resimden 1. Garmin Nuvi 1490T Speaker Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: adım 8, 3 resimden 1. Garmin Nuvi 1490T Speaker Replacement: adım 8, 3 resimden 2. Garmin Nuvi 1490T Speaker Replacement: adım 8, 3 resimden 3.
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
Sonuç
Ricardo Solis
1.037 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Remmell Spring 2016 USF Tampa, Team 15-2, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 273
