Ana içeriğe geç
Garmin Nuvi 200 Speaker Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: adım 1, 2 resimden 1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: adım 1, 2 resimden 2.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: adım 3, 2 resimden 1. Garmin Nuvi 200 Speaker Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    there is no use showing how to replace a speaker in nuvi if we cant find any
    seems like a god dam mistery
    Jean Michel Tche - Yanıt
  5. Garmin Nuvi 200 Speaker Replacement: adım 5, 1 resimden 1.
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: adım 6, 3 resimden 1. Garmin Nuvi 200 Speaker Replacement: adım 6, 3 resimden 2. Garmin Nuvi 200 Speaker Replacement: adım 6, 3 resimden 3.
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Anjelica
564 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G90
4 Üyeler
9 adet Kılavuz yazıldı
2Kılavuz Yorumları
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Yanıt
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 7,131
