Ana içeriğe geç
Garmin Nuvi 200W Rear Cover Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: adım 1, 3 resimden 1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: adım 1, 3 resimden 2. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: adım 1, 3 resimden 3.
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: adım 2, 1 resimden 1.
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: adım 3, 3 resimden 1. Garmin Nuvi 200W  Rear Cover Replacement: adım 3, 3 resimden 2. Garmin Nuvi 200W  Rear Cover Replacement: adım 3, 3 resimden 3.
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: adım 4, 2 resimden 1. Garmin Nuvi 200W  Rear Cover Replacement: adım 4, 2 resimden 2.
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
Sonuç
Matthew Eires
319 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 278
