Ana içeriğe geç
Garmin Nuvi 2455LMT Touch Screen Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2455LMT Touch Screen Replacement, Back Panel Assembly: adım 1, 1 resimden 1.
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 2, 2 resimden 1. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 3, 3 resimden 1. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 3, 3 resimden 2. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 3, 3 resimden 3.
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: adım 4, 2 resimden 1. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: adım 4, 2 resimden 2.
    • Locate the edge of the screen that fits into the plastic case
    • To separate the connector, gently push the tip of a spudger under the clip.
    • Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
  5. Garmin Nuvi 2455LMT Touch Screen Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to wedge between the plastic cover and screen.
    • Using your hands, gently push the front of the screen towards you to push the screen out of the casing.
Sonuç
Torrance Williams
229 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 624
