Ana içeriğe geç
Garmin Nuvi 2557LMT Battery Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2557LMT Battery Replacement, Garmin Nuvi 2557LMT Disassembly: adım 1, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Battery Replacement: adım 2, 1 resimden 1.
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Battery Replacement: adım 3, 1 resimden 1.
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Battery Replacement: adım 4, 2 resimden 1. Garmin Nuvi 2557LMT Battery Replacement: adım 4, 2 resimden 2.
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Battery Replacement: adım 6, 1 resimden 1.
    • Pull the battery-motherboard connector away from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
On my Nuvi 2557, the silver name bezel is part of the front cover - it does not separate. I just split the case as shown.
The battery connector pulls out perpendicular to the pc board, and you re-insert it by aligning and pressing down against the board.
john horn - Yanıt
Would this apply to the Nuvi 2555LMT?
Bill Hines - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,250
