Ana içeriğe geç
Garmin Nuvi 2557LMT Speaker Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2557LMT Speaker Replacement, Garmin Nuvi 2557LMT Disassembly: adım 1, 1 resimden 1.
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Speaker Replacement: adım 2, 1 resimden 1.
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Speaker Replacement: adım 3, 1 resimden 1.
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Speaker Replacement: adım 4, 2 resimden 1. Garmin Nuvi 2557LMT Speaker Replacement: adım 4, 2 resimden 2.
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  6. Garmin Nuvi 2557LMT Speaker Replacement: adım 6, 1 resimden 1.
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 194
