Ana içeriğe geç
Garmin Nuvi 255W Logic Board Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: adım 1, 2 resimden 1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: adım 1, 2 resimden 2.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: adım 2, 1 resimden 1.
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: adım 3, 2 resimden 1. Garmin Nuvi 255W Logic Board Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: adım 4, 1 resimden 1.
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: adım 5, 1 resimden 1.
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: adım 6, 2 resimden 1. Garmin Nuvi 255W Logic Board Replacement: adım 6, 2 resimden 2.
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: adım 7, 2 resimden 1. Garmin Nuvi 255W Logic Board Replacement: adım 7, 2 resimden 2.
    • Detach the logic board form the battery by pulling out the cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anjelica
564 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G90
4 Üyeler
9 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 10,510
