Ana içeriğe geç
Garmin Nuvi 2595LMT USB Port Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2595LMT USB Port Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: adım 1, 1 resimden 1.
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT USB Port Replacement: adım 2, 2 resimden 1. Garmin Nuvi 2595LMT USB Port Replacement: adım 2, 2 resimden 2.
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT USB Port Replacement: adım 3, 3 resimden 1. Garmin Nuvi 2595LMT USB Port Replacement: adım 3, 3 resimden 2. Garmin Nuvi 2595LMT USB Port Replacement: adım 3, 3 resimden 3.
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
    The ribbon connector is held in place by a white plastic bar that snaps in place. It will pop up when lightly pried from the ribbon side as shown in the photo (the pivot action is on the connector side). Putting it back together is tricky. The ribbon cable has to lie flat in the connector as far back as possible; once this is true then snap the lever flat against the cable and lock it in place.  You might feel a very subtle snap sensation.
    dec59us - Yanıt
    I simply can't make this work.
    daBee -
    I replaced the battery in my Garmin 2595 and I couldn't get the screen to light up. I called Garmin for assistance and was told that my Garmin's battery could not be replaced and because I broke the seal in the back there was nothing that could be done to correct my problem. Meaning when this Garmin's battery goes bad, you must throw the unit away!!! I tried to explain there are all kinds of videos showing how to replace the battery, but I was told, none of them were from Garmin so there was nothing they could do for me!!!
    Raymond S Yankura - Yanıt
    Yeah, that ribbon clip is impossible to get back into that slot and locked. I found a proper battery, but the unit is now broken because it won't seat at all.
    daBee - Yanıt
  4. Garmin Nuvi 2595LMT USB Port Replacement, USB Port: adım 4, 3 resimden 1. Garmin Nuvi 2595LMT USB Port Replacement, USB Port: adım 4, 3 resimden 2. Garmin Nuvi 2595LMT USB Port Replacement, USB Port: adım 4, 3 resimden 3.
    • Remove the t5 screwdriver head and replace it with the j000 screwdriver head from the toolkit.
    • Disconnect all the wires from the circuit board.
    • Using the j000 screwdriver, remove all four 5.1mm screws from the circuit board and place them safely on the table (separate from the case ones)
    • Gently pry circuit board from the bottom shell and place it gently on the work surface
  5. Garmin Nuvi 2595LMT USB Port Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently and delicately heat up the solder holding the USB port to the circuit board.
    • Carefully remove the USB Port using the metal tweezers from the toolkit.
    • Place the old USB Port on a protected work surface that won’t light on fire.
    A few comments on separating the screen cables from the main unit would be helpful.. This is not obvious after prying the two components apart.
    thomjc24 - Yanıt
  6. Garmin Nuvi 2595LMT USB Port Replacement: adım 6, 1 resimden 1.
    • Grab the replacement USB port with the metal tweezers from the toolkit.
    • Grab the solder and place it on the location of the previous USB port.
    • Place the replacement port and place it over the solder.
    • While holding the USB port in place with the tweezers, use the soldering iron to heat up the solder underneath the port.
    • Let the port cool for an hour.
    Please send me manufacture part number of USB port and where I can buy that. I am from Canada. Mohan
    Email
    A
    mohan_bhambra@yahoo.ca
    Mohan - Yanıt
    Manufacturing of USB port and part number
    Mohan - Yanıt
    Email: bradmichaelonline@gmail.com
    brad - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
14Kılavuz Yorumları
where to buy the replacement part?
Philip Bauyon - Yanıt
The link to the Garmin Nuvi 2595lmt Replacement Port show 3 legs and in the picture above there hare 5 legs
liordaniel - Yanıt
The part for sale on eBay and the one in the pictures are not the same connector. If you want to read more about this problem try this link:
http://www.sharc.net/gps_charger_repair....
sharcnetusa - Yanıt
The link points to a different kind of connector, while it's not 3 pin (the two additional pins are a bit in behind the row of 3 pins) it's wrong and won't work.
However I did not need a new connector, just solder back the current connector and it now works fine (until next time).
One thing that isn't to clear is that the battery and speaker wires are pulled straight up from the board, not sideways in the connector as I first thought.
lpaseen - Yanıt
Great info, exactly the fix I need.
just cant seem to find the USB port replacement for my nuvi 2595lm.
Any one knows were I can get one from?
Zac - Yanıt
Anybody know where to get the usb part?
This guide is perfect but I need to replace the port rather than re-attach it.
I am struggling to source the part.
Pat Obrien - Yanıt
Also looking for this OEM part - any luck?
Eric - Yanıt
its hard to get hold of them any other sources? if all fails i will end up modify with another port and have a extension made. lets see how it goes
SHAIK Rahman - Yanıt
where can i find this replacement port PLS
pdsalva - Yanıt
Same problem here. Someone must make these parts.
Gregg Snabb - Yanıt
I have the same issue as Zac. I need one for a 2595 or 2595lm? Any suggest will be appreaciated
David Norwood - Yanıt
The amazon link does not have the usb replacement part any longer
where do we go to buy the replacement usb port
email: bradmichaelonline@gmail.com
brad - Yanıt
Garmin Nuvi 44 lm part is different what is the part?
27grains - Yanıt
I have a Garmin GPS and I believe I have a bad USB port and would like to locate one. The link to Amazon does not show one. Is it still possible to purchase one. Your help would be appreciated.
LOUIS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 18,014
