Ana içeriğe geç
Garmin Nuvi 260W Circuit Board Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 260W Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Circuit Board Replacement: adım 3, 2 resimden 1. Garmin Nuvi 260W Circuit Board Replacement: adım 3, 2 resimden 2.
    • Once screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Circuit Board Replacement: adım 4, 1 resimden 1.
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Circuit Board Replacement: adım 5, 1 resimden 1.
    • Once the body of the nüvi is separated and the ribbon cable is disconnected, remove the three 1.6mm Phillips #0 screws.
  6. Garmin Nuvi 260W Circuit Board Replacement: adım 6, 1 resimden 1.
    • Carefully disconnect the two cables connecting the battery to the motherboard and remove motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hunter Johnson
327 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Spring 2018 IUPUI, Team S3-G5, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 481
