Ana içeriğe geç
Garmin Nuvi 2797LMT LCD Screen Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 2, 3 resimden 1. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 2, 3 resimden 2. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 2, 3 resimden 3.
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 3, 1 resimden 1.
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 4, 1 resimden 1.
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 5, 2 resimden 1. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 5, 2 resimden 2.
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 6, 2 resimden 1. Garmin Nuvi 2797LMT LCD Screen Replacement: adım 6, 2 resimden 2.
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
baileykaytar
366 İtibar
2 adet Kılavuz yazıldı
Ekip
2 Yorum
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - Yanıt
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 2,394
