Ana içeriğe geç
Garmin Nuvi 42LM Battery Replacement
Neye ihtiyacın var
    1. Garmin Nuvi 42LM Battery Replacement, Battery: adım 1, 3 resimden 1. Garmin Nuvi 42LM Battery Replacement, Battery: adım 1, 3 resimden 2. Garmin Nuvi 42LM Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Garmin Nuvi 42LM Battery Replacement: adım 2, 3 resimden 1. Garmin Nuvi 42LM Battery Replacement: adım 2, 3 resimden 2. Garmin Nuvi 42LM Battery Replacement: adım 2, 3 resimden 3.
      • Pry the GPS open using a plastic opening tool.
      • When prying open the device, use caution to avoid damaging the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Garmin Nuvi 42LM Battery Replacement: adım 3, 3 resimden 1. Garmin Nuvi 42LM Battery Replacement: adım 3, 3 resimden 2. Garmin Nuvi 42LM Battery Replacement: adım 3, 3 resimden 3.
      • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
      • There are two screws - one in the back and one in the front.
      FixBot'a Sor
      Yorum Ekle
    4. Garmin Nuvi 42LM Battery Replacement: adım 4, 1 resimden 1.
      • Move the motherboard from from its designated location on the GPS.
      • Do not pull on red, green, and black cables when repositioning the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Garmin Nuvi 42LM Battery Replacement: adım 5, 2 resimden 1. Garmin Nuvi 42LM Battery Replacement: adım 5, 2 resimden 2.
      • Gently unplug the red, green, and black bundled cable to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    6. Garmin Nuvi 42LM Battery Replacement: adım 6, 2 resimden 1. Garmin Nuvi 42LM Battery Replacement: adım 6, 2 resimden 2.
      • Use blue plastic opening tool to carefully pry the battery from the GPS.
      • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
on my Nuvi 55-diconnected ribbon cable by accident. When I reconnect I get a white screen. How to get the terminals to line up correctly?
Mike - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 36
Her zaman: 1,755
