Ana içeriğe geç
Garmin Nuvi 56LMT Battery Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: adım 1, 2 resimden 1. Garmin Nuvi 56LMT Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: adım 2, 3 resimden 1. Garmin Nuvi 56LMT Battery Replacement: adım 2, 3 resimden 2. Garmin Nuvi 56LMT Battery Replacement: adım 2, 3 resimden 3.
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: adım 3, 3 resimden 1. Garmin Nuvi 56LMT Battery Replacement: adım 3, 3 resimden 2. Garmin Nuvi 56LMT Battery Replacement: adım 3, 3 resimden 3.
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: adım 4, 3 resimden 1. Garmin Nuvi 56LMT Battery Replacement: adım 4, 3 resimden 2. Garmin Nuvi 56LMT Battery Replacement: adım 4, 3 resimden 3.
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: adım 5, 1 resimden 1.
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Sonuç
Christopher Keller
102 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Nance Fall 2017 USF Tampa, Team S3-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 416
