Ana içeriğe geç
Garmin Nuvi 56LMT Display Screen Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 56LMT Display Screen Replacement, Display Screen: adım 1, 1 resimden 1.
    • Power down the device before proceeding.
    • Locate the four 11.0 mm Torx screws and remove them with the T5 Torx screwdriver.
  2. Garmin Nuvi 56LMT Display Screen Replacement: adım 2, 1 resimden 1.
    • Find the crevice where the front and back of the device meet.
  3. Garmin Nuvi 56LMT Display Screen Replacement: adım 3, 1 resimden 1.
    • Run the plastic opening tool around the border of the device until it can be easily pried open by hand.
    • Be careful to not damage the ribbon cable by completely pulling the back from the front.
  4. Garmin Nuvi 56LMT Display Screen Replacement: adım 4, 1 resimden 1.
    • Carefully use the spudger to flip open the ZIF connector.
  5. Garmin Nuvi 56LMT Display Screen Replacement: adım 5, 2 resimden 1. Garmin Nuvi 56LMT Display Screen Replacement: adım 5, 2 resimden 2.
    • With your fingers hold back each of the clips located around the border of the screens back.
    • Pull screen up and slide out in the opposite direction of the ribbon to avoid snapping the fixed clips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Saxon
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Nance Fall 2017 USF Tampa, Team S3-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 285
