Ana içeriğe geç
Garmin Nuvi 65LM Car Charger Fuse Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: adım 1, 3 resimden 1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: adım 1, 3 resimden 2. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: adım 1, 3 resimden 3.
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: adım 2, 3 resimden 1. Garmin Nuvi 65LM Car Charger Fuse Replacement: adım 2, 3 resimden 2. Garmin Nuvi 65LM Car Charger Fuse Replacement: adım 2, 3 resimden 3.
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: adım 3, 1 resimden 1.
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Sonuç
Kai Ling Liang
246 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-3, Amido Spring 2015 Cal Poly, Team 15-3, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,079
