Ana içeriğe geç
Garmin StreetPilot C330 Outer Casing Replacement
Neye ihtiyacın var
  1. Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: adım 1, 3 resimden 1. Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: adım 1, 3 resimden 2. Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: adım 1, 3 resimden 3.
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot C330 Outer Casing Replacement: adım 2, 3 resimden 1. Garmin StreetPilot C330 Outer Casing Replacement: adım 2, 3 resimden 2. Garmin StreetPilot C330 Outer Casing Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot C330 Outer Casing Replacement: adım 3, 2 resimden 1. Garmin StreetPilot C330 Outer Casing Replacement: adım 3, 2 resimden 2.
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot C330 Outer Casing Replacement: adım 4, 3 resimden 1. Garmin StreetPilot C330 Outer Casing Replacement: adım 4, 3 resimden 2. Garmin StreetPilot C330 Outer Casing Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot C330 Outer Casing Replacement: adım 5, 1 resimden 1.
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adrian Leon
173 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,968
