Ana içeriğe geç
Garmin StreetPilot c320 Rear Case Assembly Replacement
Neye ihtiyacın var
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: adım 1, 2 resimden 1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: adım 1, 2 resimden 2.
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: adım 2, 2 resimden 1. Garmin StreetPilot c320 Rear Case Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: adım 3, 1 resimden 1.
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Sonuç
Andrew Burman
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 üyesi
CPSU-MANESS-W12S11G19
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,403
