Giriş
Before you begin disassembling the device, be sure the power is off. For this guide you will need to know how to use a soldering iron. For help with soldering look at this guide.
Neye ihtiyacın var
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two #00 Phillips screws securing the battery to the rear case assembly.
Neredeyse bitti!
Sonuç
